How to get microphone loopback without delay?
Go to solution Solved by thekeemo,
have a 3.5 male2male going from another out to a line in ?
Going from using turtle beaches for a few years hearing my voice through the mic. Kinda weird not hearing myself when I talk using the hyperx clouds, I always feel like im shouting.
CPU -  Intel i7 4770k 4.6Ghz     Motherboard - MSI GD-65    RAM - Corsair Vengeance 16 GB     GPU - XFX 295x2    Case - NZXT H440
Storage - 256GB OCZ Vertex 4 ssd, 1TB WD Blue 7200rpm    PSU -  EVGA SuperNOVA 850 G2  Cooling - Corsair H80i     Keyboard - KGParadise v60 w/ cherry mx greens
Mouse -Theron  Sound - HyperX Cloud
https://linustechtips.com/topic/227011-how-to-get-microphone-loopback-without-delay/
Pretty sure windows has an option to "listen" to a  recording device, right click speaker in bottom right then click recording devices then pick you mic, go properties then listen then listen to this device
5820k@3.8GHz| Corsair H100i |Gigabyte x99 SLI | Corsair 16GB | EVGA 780Ti SC ACX SLI x2 |240GB SSD120GB SSD 512GB SSD 2TB HDD | 3x ASUS VN247H 24" ( nVidia Surround)
theres a 1second delay with this
ah didnt know
Yeah :3 makes it even worse lol I get tongue tied with it
Dont quite get what you're saying
use a male-male 3.5mm cable and plug it into both a audio out and a line in
So I plug my mic and headset and normally through the green and pink ports and use the front ports and put the male-male cable there?
yes but I would use the line in instead of the mic (its the orange)
Will give it a try, I have a cable around here somewhere.
Have it plugged in, what do I do? I dont hear myself I imagine im missing something
plugged into green and orange?
Yes sir.
@moonedunk
open playback devices --> open recording ---> right click on mic and choose properties --> go to listen
could have done that from the beginning what I was doing is making your computer audio work like a mic #facepalm
@moonedunk
open playback devices --> open recording ---> right click and choose properties --> go to listen
Im dumb LOL. Has a slight delay but nothing too bad. Thanks man,
