Yo community!
Can anyone suggest me a laptop that costs about $400 and can run dota 2 with no problems? I'm not really experienced with laptops
Thanks!
Edit:
Is this a good value?
http://www.tipidpc.com/viewitem.php?iid=24425852
This costs around $370 if converted
https://linustechtips.com/topic/22688-help-laptop-around-400/
Dota would be hard on a laptop, woudnt it?
Anyway, maybe look for a pre owned gaming laptop, doesnt take much to run dota.
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/22688-help-laptop-around-400/#findComment-286951
http://www.ncix.ca/products/?sku=79722&vpn=C7C76UA%23ABA&manufacture=HP%20Consumer&promoid=1322
Would something like this work for you? It doesn't say what the speed of the ram is, but for a little added boost, you could grab the fastest compatible 8GB kit for it, since those APU's use the system memory for their GPU as well. SOmeone please correct me if I am wrong, I haven't researched these in some time.
CPU:i7-4770K @ 4.3GHz | GPU: 2 x GTX 980's | Mobo: Asus Maximum Hero VII | RAM: 16GB's ARES GSkill @ 1600MHz | PSU: Corsair AXI 760W | OS: Win 8.1 Professional 64-bit | Monitor: 27" 1440p IPS panel | Heatsink: H100i
https://linustechtips.com/topic/22688-help-laptop-around-400/#findComment-288069
