Waterfox help?
Go to solution Solved by ForsakenLive,
That's the default start page for every waterfox user, it doesn't matter if you have firefox or not. I don't have the basic start page predetermined, I have my own start page.
Basically, deal with it :)
Downloaded Waterfox. Best thing I've ever used since forever. It's my new google chrome. Well, there's only 1 teeny tiny problem that I have. You know what, it's not a problem at all, just my preference. So on the start page there should be the sexy a** Waterfox logo, but on mine, there is a firefox logo.
Is there a way to fix it? Should I uninstall Firefox?
https://linustechtips.com/topic/226547-waterfox-help/
Oh okay then. Because whenever I refresh my home page, the waterfox logo pops up for a quick second and then it turns back to the Firefox page. Thanks!
https://linustechtips.com/topic/226547-waterfox-help/#findComment-3103702
