[Keyboard] Problem with "duplicating keystrokes"
Solved by Enderman,
Thanks fo your quick reply, I dont want to be rude but, I hope you are wrong.
I am wrong. It's actually worse than that.
I just googled it, and it seems like that keyboard has an issue with double keystrokes, as you can see from this review: http://hothardware.com/Reviews/Gigabytes-Osmium-Keyboard-Great-Design-Flawed-Execution/?page=3
This means that you won't be able to RMA it either, because its actually not defective, that's "normal" for the keyboard.
SO you're going to have to live with it until you can buy a new keyboard.
