I play on 1080p 1 monitor.
I have 280x gigabyte edition and I have fps drops on Lol and payday 2 from high fps 80-100+ and then to 6-20fps.
I have fx 6300 processor.
I know LoL is bad optimised for multicore processor but not brother has same processor and 270x and says that he has no problem with it, he used to have fps drops like this but not anymore. He said that he uninstalled his graphic card driver then re install them.
I have done that and checked that I have the newest drivers.
Processor is overclocked to 4,3 ghz.
Any know how to fix this?
PC  Specs 2022:
  • CPU
    AMD Ryzen R9 5900x @ 5.1GHz - Auto OC
  • Curve Optimizer Magnitude: -20
  • Motherboard
    ASUS ROG STRIX x570-F Gaming
  • RAM
                                        Kingston Fury 32GB DDR4 3200MHz 16x2GB
  • GPU
    MSI 3070 8GB Ventus 2x OC
  • Case
    LIAN LI LANCOOL MESH II Mesh RGB Black
  • Storage
    Kingston NV1 2TB M.2. NVMe
  • PSU
    Seasonic Focus GX 850w
  • Display(s)
    MSI OPTIX MAG 251RX IPS 240hz & ASUS MG248Q Vertical 144hz & Dell 60hz
  • Cooling
    NZXT Kraken x73 360mm
  • Keyboard
    Tt eSports Meka G1
  • Mouse
    Logitech G Pro Wireless
  • Operating System
    -Windows 10 Professional 64bit
https://linustechtips.com/topic/225780-fps-problem-280x/
when testing for problems remove all overclocks.
might be you processor being unstable.
run it stock and come back with results
Can't I test it in some other way?
Prime 95 works fine, but I can try that some more I have only done it about 5 min per session.
My temp is below 60 on cpu and below 80 on gpu.
I have cm 212 evo.
I'll be sure to try it though but yeah I would rather not :P
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/225780-fps-problem-280x/#findComment-3092838
remove the overclock, check the temps on both CPU,GPU (on full load), check the CPU-GPU usages whan the FPS drops. Do you have a stock cooler on the CPU?
"like if you could buy two Xbox Ones, put them togheter and actually play games at 1080P! Ha! BURN"
-Linus
https://linustechtips.com/topic/225780-fps-problem-280x/#findComment-3093285
Please read the previous replies before typing things like this ..
"My temp is below 60 on cpu and below 80 on gpu.
I have cm 212 evo." Posted Today, 07:22 PM
But yes I can do more specific tests like while running (specific) games.
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/225780-fps-problem-280x/#findComment-3093616
try. try.
I don't play much since I don't have much time with school and stuff but when I have time I will save and then do default settings.
I don't see how it should matter though.
When I think of it I only remember this happening to these 2 games. To other games I think it's fine, even though I haven't tried out many of them.
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/225780-fps-problem-280x/#findComment-3094093
sorry :D
-Linus
https://linustechtips.com/topic/225780-fps-problem-280x/#findComment-3094506
when testing for errors you must remove as many breaking points as possible.
https://linustechtips.com/topic/225780-fps-problem-280x/#findComment-3098860
Ok.
I can do it today or maybe tomorrow I think.
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/225780-fps-problem-280x/#findComment-3098895
On a unrelated note 3 of my steam games stuck in update queue required but never updates and steam self update doesn't work. It goes to maximum 0,61 mb or something.
those games are cpu intensive games and use only 1 CPU core for processing, the only way to really improve performance is to go with a cpu that has faster cores, intel pentium G3258 overclocked for example will deliver ''as good as it gets'' performance in those titles. So would a core i3 or core i5 haswell CPU.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/225780-fps-problem-280x/#findComment-3098902
I already have this for my computer so I can't/will not buy new until 3-5 years later.
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/225780-fps-problem-280x/#findComment-3099115
i understand, some games will suffer from poor single-threaded performances, mostly online MMO's and RTS and some indie games...
the FX-6300 as somewhat good multi-threaded performance though so you are less likely to encounter this problem when running modern games such a battlefield 4, Far cry or crysis for example.
https://linustechtips.com/topic/225780-fps-problem-280x/#findComment-3099134
I usually don't play those though.
I play some steam games and try to focus on LoL but that doesn't work out very good. I lost the spark or something. My next computer might be i5 with nvidia though. The gtx 900 series look tempting.
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/225780-fps-problem-280x/#findComment-3099829
you need to check if while playing your CPU or GPU usage drops.
I need to tab out to have those kinds of monitor thingies open. Is there a program/app that can monitor it in charts or something similar to afterburner but for cpu?
I just come to think of Kombustor I guess I can use that.
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/225780-fps-problem-280x/#findComment-3100386
afterburner will show you all you want to see including CPU core loads and RAM usage, use the rivatuner app (included) to show on screen (in OSD: on screen display)
Monitor mostly your GPU load, it should be 95% and up when vsync is off.
https://linustechtips.com/topic/225780-fps-problem-280x/#findComment-3100461
For the steam game updates right click and should be a (verify cache) click this it should update.
I tried that and it didn't help.
I managed to get it working though. I looked at "programs that might interfere with Steam" and found avg (my anti virus software).
I turned it off then everything worked perfectly. With steam.
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/225780-fps-problem-280x/#findComment-3105595
Ok, I'll try that whenever I play.
I see cpu stats/graphs with rivatuner?
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/225780-fps-problem-280x/#findComment-3105596
There is not default button in bios so I turned everything I saw to auto and put on cool and quiet.
I played 1 aram match (LoL's most demanding map) and I didn't have a single fps drop.
Which is weird because I did prime 95 for 30 min and I don't think I had any problems.
I have 212 evo and oc'd it to 4.3 ghz that's not much.
post-109852-0-01087900-1412500979_thumb.
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/225780-fps-problem-280x/#findComment-3118961
