Asus Essence STX II 7.1
https://linustechtips.com/topic/225544-best-sound-card/#findComment-3089594
Is this sound card in pc part picker?
http://pcpartpicker.com/part/asus-sound-card-xonaressencestx
If you wan't something almost as good, but way cheaper http://pcpartpicker.com/part/creative-labs-sound-card-70sb155000001
https://linustechtips.com/topic/225544-best-sound-card/#findComment-3089623
I have the xonar dx and really enjoy it. It's ideal for use with speakers and works well with my iem's too.
If you use headphones with a higher impedance or think you may do in the future the xonar dg may be the better option since it has a built in amp.
https://linustechtips.com/topic/225544-best-sound-card/#findComment-3093802
