Gaming Pc Build help!
Go to solution Solved by vern021,
This is a build where I can't change anything to make it better because IT IS solid. Good job. :)
Hello everyone. I've been trying to get into PC gaming but I've run into some financial issues. I'm now back on track and getting close to my getting my PC. I had ordered my case before i ran into money issues so i don't need a case but i need the rest of my parts to be UNDER $1000. I have the rest of my parts picked out But this is my first build and I'm not a complete expert with this stuff.
My planned build
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($234.98 @ OutletPC)
Motherboard: MSI Z97-G55 SLI ATX LGA1150 Motherboard  ($117.98 @ SuperBiiz)
Video Card: EVGA GeForce GTX 970 4GB ACX Video Card  ($329.98 @ NCIX US)
Case: Corsair 230T Windowed-BLUE ATX Mid Tower Case  (Purchased For $0.00)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($99.99 @ Newegg)
Total: $980.39
Generated by PCPartPicker 2014-09-30 20:29 EDT-0400
 Is this a solid build? This will be a gaming PC Note I'm in the USA. If you have any questions ask away down below.
https://linustechtips.com/topic/225402-gaming-pc-build-help/
My Current PC Codename: Scrapper
Intel i5-3570 | Some LGA 1155 MOBO Some Generic DDR3 8GB 1600Mhz | PowerColor RX 560 2GB | Recycled HP Case Crucial MX100 128GB 1TB WD Blue 7200RPM | Some Generic 500w PSU | Intel Stock Cooler
https://linustechtips.com/topic/225402-gaming-pc-build-help/#findComment-3087688
There's not much we can change, because this build is already rock solid as can be.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/225402-gaming-pc-build-help/#findComment-3087721
Looks very good! Obviously an SSD would be nice but to fit one you'd have to forgo the 970 so I'd say keep the 970 and get the SSD in the future. Also you may wish to consider buying the retail version of Windows 8.1, it doesn't actually cost that much more but there'll be less future hassle with upgrades (I think...?). Probably not that much of an issue though so I'd say you're good to go :)
https://linustechtips.com/topic/225402-gaming-pc-build-help/#findComment-3087781
