pre-calculus help
I need help for on my pre-calculus homework. It says "Rewrite the rational function as the sum of a polynomial and a rational function whose numerator has a smaller degree than it's denominator.(Remember, a polynomial can be a constant.)" The function is f(x)=(x^3-1)/x-2). Thanks!
https://linustechtips.com/topic/225353-pre-calculus-help/
42, the answer is 42.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/225353-pre-calculus-help/#findComment-3086995
Use synthetic division
2| 1 0 0 -1
_______
    1 2 4 7
x^2 + 2x + 4 + 7/(x-2)
I'm pretty sure this i sthe solution.
edit: crap changed the numbers
Gaming Rig: i5-3570k+H100i (4.3 ghz) | P8Z77-i Deluxe | MSI Twin Frozr 7950 Boost | HX650 | 1TB HGST | 840 Evo 250 GB
https://linustechtips.com/topic/225353-pre-calculus-help/#findComment-3087025
In dentistrycalculus or tartar is a form of hardened dental plaque. It is caused by the continual accumulation of minerals from saliva on plaque on the teeth. Its rough surface provides an ideal medium for further plaque formation, threatening the health of the gingiva (gums).
Brushing and flossing can remove plaque from which calculus forms; however, once formed, it is too hard and firmly attached to be removed with a toothbrush. Calculus buildup can be removed with ultrasonic tools or unique hand instruments (such as a periodontal scaler).
https://linustechtips.com/topic/225353-pre-calculus-help/#findComment-3087185
