Hey i just got my new gtx 980 (refernce zotac) and the thing is running like a beast but i cant get it to work in unigine valley/heaven (it always starts valley/heaven and after a sec it stops and clocks the gpu down to factory) when getting over 1400 MHz while its sitting on an under 70 degrees and using never more then 114% power usage (using msi afterburner) in furmark for example its running just fine... could it just need more voltage??? am is stupid or is it some unigine problem???
https://linustechtips.com/topic/225247-unigine-overclocking-problems/
throw Valley in the toilet. Only had problems with it. Run games. That's the best benchmark. run a fraps benchmark if youw ant averages etc.
5.1GHz 4770k
My Specs
Intel i7-4770K @ 4.7GHz | Corsair H105 w/ SP120 | Asus Gene VI | 32GB Corsair Vengeance LP | 2x GTX 780Ti| Corsair 750D | OCZ Agility 3 | Samsung 840/850 | Sandisk SSD | 3TB WD RED | Seagate Barracuda 2TB | Corsair RM850 | ASUS PB278Q | SyncMaster 2370HD | SyncMaster P2450
