I was orginally going to just buy an aftermarket mcp655 top along with a seperate tube res, but it seems like a better deal to just get the mcp655 along with a tube res top. I was wondering if anyone would reccomend this res, if not do you have any in mind? I can't have it too big nor expensive, and I'd like to stick with a tube res as I think they look cool.
Thanks
Me: Yeah I just really can't get my H220 working again, I've tried everything that was suggested in the forum.
Brian (Swiftech Support): Hmm, have you tried slapping it?
https://linustechtips.com/topic/22516-d5-top-res/
its a pretty small tube res...and ek is an awesome brand...also you should know with these res the res feeds directly into the pump but once circulated it will come back in to the pump top...unless you use the fillport as the inlet...heh some people dont like that....
there are also these http://www.frozencpu.com/products/12199/ex-pmp-122/Bitspower_D5_MCP655_Extreme_Pump_Mod_Top_V2_-_Acetal_BP-D5TOPP2EX-BK.html
 where you can attach a tube top to it...from the 4 screws in the corners.. :)
https://linustechtips.com/topic/22516-d5-top-res/#findComment-284051
EK components are great. Also saw someone of the well known modders/watercooled cp builders on youtube recommend it.
Christopher Kruse | Webdeveloper (Interface & Applications)
i7 3770k (3233C Batch) @ 4.2ghz | Asus P8Z77 WS | Gigabyte 780 Ti OC  | Corsair Vengeance LP 1600 32GB DDR3 | Samsung 850 EVO 500GB +2x Samsung 840 EVO 250GB + Samsung 830 256GB + 4x WD30EFRX, 2x WD30EZRX, 1xWD20EARS | Corsair AX750 + Bitfenix Extensions | Fractal Design Define XL R2 + Xigmatec 3in3 Hotswap Cage | Noctua NH-D15 + Thermal Grizzly Kryonaut, 5x Noctua NF-P14s redux-1500 PWM | Peripherals: Logitech G502 + Corsair K70 RGB + Red 40A-L O-Rings | Sound: Denon AVR 2807 via HDMI + 2x Nubert nuPro A-20 + 1x B&W CC6 Center | SoundMagic E10 | Jabra Speak 410
https://linustechtips.com/topic/22516-d5-top-res/#findComment-284052
I don't fulling understand what you mean? Also it's too expensive for me to buy that plus a tube top
https://linustechtips.com/topic/22516-d5-top-res/#findComment-284075
Just get the EK one, if you don't have a massive cooling loop. You could also replace the tube itself with a larger one at a later point in time.
https://linustechtips.com/topic/22516-d5-top-res/#findComment-284095
singulatiry computers does some masterpieces!!
Yes, Singularity Computers is probably the culprit, since he is the only modder, to whom i'm subscribed to currently. Love his builds, actually got me back into modding again.
https://linustechtips.com/topic/22516-d5-top-res/#findComment-284131
I can recommend this pump top/res.
it comes with a mounting bracket to screw it into 2 M4 holes (You need to drill these into something, like a drive cage)
Oh cool, I'm going to try to use double side adhesive instead of screws, not sure how it's going to work. How easy is it to fill?
https://linustechtips.com/topic/22516-d5-top-res/#findComment-284287
(Ignoring all the other replies (sorry))
That is a good tube res. You can buy a longer cylinder for that res if you want to make it longer.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/22516-d5-top-res/#findComment-288156
I think its perfectly valid to express your opinion, even if said opinion already got expressed by others. Freedom of Speech, the internet still got it :D
https://linustechtips.com/topic/22516-d5-top-res/#findComment-288538
tube res meh, bay res ftw
Well, if you like the sound... I think it's cool for a show case, but not for everyday working.
https://linustechtips.com/topic/22516-d5-top-res/#findComment-288546
As in I didn't bother reading all the other replies.
https://linustechtips.com/topic/22516-d5-top-res/#findComment-288563
That doesn't make it invalid :P
Probably could have just quoted my post (#5) if you had read them :D
PS. @Owen, what was your budget again?
https://linustechtips.com/topic/22516-d5-top-res/#findComment-288602
I'm on my phone and can't figure out how to quote so hopefuly you're following the post :p Excluding the pump its self I'd like to not spend more than 70ish on a res/pump top, preferably less
https://linustechtips.com/topic/22516-d5-top-res/#findComment-288631
I'm on my phone and can't figure out how to quote so hopefuly you're following the post :P Excluding the pump its self I'd like to not spend more than 70ish on a res/pump top, preferably less
No worries, i auto follow all topics i reply too.
Okay, just askin because i sometimes get some great offers on pumptop + res combos, i'll look around.
But honestly, i would just get the EK D5 X-Res for myself. Also there is a 140mm version, if you didn't know.
https://linustechtips.com/topic/22516-d5-top-res/#findComment-288649
Oh great, I didn't see the larger version thanks. Ya let me know if you see anything that pops out, I'll probably be ordering all my stuff in the next few days.
https://linustechtips.com/topic/22516-d5-top-res/#findComment-288669
Mine does't make noise that one is not in a loop so runs way faster obviously max speed.
oh ok good I thought that sounds was odd. I prefer the look of tube res's better anyway, though.
https://linustechtips.com/topic/22516-d5-top-res/#findComment-288933
