For some reason If I try to watch netflix in chrome, I don't have the HD indicator or quality. If I try the same in Internet Exploder, it works just fine. Here is an example.
The second image is from exploder. Chrome doesn't seem to be using silverlight.
https://linustechtips.com/topic/224858-hd-problem-on-netflix/
Ah Kyle XY. I loved that show when it came out, too bad it was cancelled for that stupid pregnant teenager show, bs if you ask me. It was a great show.
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
https://linustechtips.com/topic/224858-hd-problem-on-netflix/#findComment-3080400
Great to see a former kyle xy fan. Yeah it seems all actual decent shows get canceled.
https://linustechtips.com/topic/224858-hd-problem-on-netflix/#findComment-3080413
I remember when that pregnant teenager show came out and they were cancelling kyle xy for it. Talk about being pissed off, I watched 3 episodes of that show and it was ridiculous. Kyle xy was hands down the best show to come out at that time and it got pushed aside for all the pregnant teen moms. Bs
https://linustechtips.com/topic/224858-hd-problem-on-netflix/#findComment-3080441
Well, then explain max bitrate differences.
I've noticed I can't get HD to stream through the HTML5 player as well.
Using this to test HTML5 playback, I believe HTML5 is capped at 1750 kbps and Silverlight is capped at 3000 kbps.
In short you need to use the Netflix App in order to achieve 1080p quality.
https://linustechtips.com/topic/224858-hd-problem-on-netflix/#findComment-3080619
