I need help, i cant find anyone who knows the answer to my problem and i would love it if someone were to help. My question/problem is, im using pcpartpicker to put together my first build and when i choose a mobo with the 970 chipset, it tells me this " Some AMD 970 chipset motherboards may need a BIOS update prior to using Vishera CPUs. " ... do i need to update the bios and if i do, how would i go about doing this, also, if it didnt need to be updated and i didnt, would there be any drawbacks? if anyone could plz help that would be great!  Here is the list of the build im planning on getting http://pcpartpicker.com/p/b9dm7P
https://linustechtips.com/topic/224699-motherboard-help/
I got that same message when I got my CPU and mobo. I didn't update my BIOS or anything and my PC works fine. I have an AMD FX-6300 and a Gigabyte GA-970A UD3P motherboard, to give you an idea. So I don't think you have to worry about it.
That model is fairly recent, so the problem doesn't really apply. Older models, like the GA-970A-UD3 (without the P) might be affected. But only if you get one that was manufactured a long time ago.
https://linustechtips.com/topic/224699-motherboard-help/#findComment-3078098
It depends on when the MoBo was made. If it's an older model and most importantly, old stock, then it is very likely. If it is newer, then you will not need to reflash the bios. Most will tell you. Keep in mind that while some motherboards support CPU-less bios reflashing, most will require a compatible CPU with the current bios to reflash thebios to the one one to support your desired CPU.
One other thing to be concerned about is that not all 970 chipsets provide great power delivery for high TDP chips. It's something you really want to look into to make sure you get the right one.
https://linustechtips.com/topic/224699-motherboard-help/#findComment-3078107
The Asrock 970 Pro3 has 4+1 phases with no heatsink. Not really good for an 8-core CPU. Certainly not if you're going to overclock. Ideally you'd go for something like the Gigabyte GA-970A-UD3P, which has 8+2 phases with a heatsink.
How would the MSI 970 Gaming  Mobo do?
https://linustechtips.com/topic/224699-motherboard-help/#findComment-3078198
The worst that could happen is that the fans just run at full speed continuously.
If your motherboard does not have enough fan headers, you can either connect fans directly to the power supply (which definitely has no fan control, so those fans would run at full speed) or get a dedicated fan controller.
https://linustechtips.com/topic/224699-motherboard-help/#findComment-3079250
If they're anything like the fans that came in my Rosewill Challenger case, then yes. My fans were 3-pin connectors with an extra molex connect just in case you don't have enough slots on the MoBo. They're not quiet though at full speed, so if that's something you care about either make sure they're running slower, or replace them.
https://linustechtips.com/topic/224699-motherboard-help/#findComment-3137376
Find either the biggest hunk of metal you can, or something that you know is grounded. The old way of doing, and usually safe unless you have cat fur for feet and are working on a shag carpet, is to simply touch the inside of your computer case every minute or so. It still works just fine so long as you aren't in a place easily susceptible to static buildup. The most common cause of static these days is removing the case from the package because many use styrofoam, and styrofoam rubbing on certain things can build up an electric charge.
https://linustechtips.com/topic/224699-motherboard-help/#findComment-3146158
  • 1 month later...
