Mouse sensitivity randomly changing
The mouse in question is a Logitech g400s that had worked fine for almost half a year, this started happening relatively recently...
When in a game or even something as simple as surfing, I notice my mouse sensitivity jumping all over the place, as if I were pressing the DPI buttons.
Sometimes it slows to a crawl with a ton of delay and sometimes it's all over the place giving me probably 5-10x my normal sensitivity. It lasts anywhere from a fraction of a second upwards to 3-4 seconds.
Everything else is fine, i get no frame drops or anything like that. There's nothing wrong with the mouse either, I've tested it on my laptop.
I've also tried plugging it in all my USB 2 and 3 ports with no effect. Unfortunately I do not own another mouse to try in this rig.
Has anyone experienced this before? Any suggestions?
Windows 7 Home Premium 64-bit
Intel® Core i7-3820 @ 4.16ghz
Gigabyte GA-X79-UD3, Socket-2011
Kingston DDR3 HyperX 1600 MHz 16GB Black
Gainward GeForce GTX 660Ti 2GB PhysX
Cooler Master GX 750W PSU
Corsair SSD Force Series 3, 120GB 2.5"
Seagate Barracuda® 7200.12 1TB (x2)
https://linustechtips.com/topic/224487-mouse-sensitivity-randomly-changing/
snip
Do you have the logitech gaming software?
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
Never installed anything for it, just plugged it in and went with it and it worked fine.
I just remembered I do have a mouse fix though, removing any software acceleration from Windows that I installed while i still used my old mx518.
I suppose i'll try reinstalling both that and drivers and see if it helps.
