Weird problem
Go to solution Solved by scaryjam823,
it's NTFS, cause it's 4TB HDD.
Oh, good idea, but problem is, I don't have CD/DVD rom at all. Can I install ubuntu on flash drive? Or are there any easy ways?
Download Unlocker. One of the best programs for windows I have ever downloaded. Used it for years to solve problems just like this. Install it, right click the file, click unlocker. Then select delete option. Done. If it can't delete it right there, it will delete when you restart your computer automatically.
Strange, but it seems I can't delete 1 mkv file on my D Disk. Other files seem ok, it's just god damn file. It's stuck on this dialog:
And the more weird is, just look at this yourself:
And my CPU temp is 52...
Can't also rename it...
| CPU: i7 3770k | MOTHERBOARD: MSI Z77A-G45 Gaming | GPU: GTX 770 | RAM: 16GB G.Skill Trident X | PSU: XFX PRO 1050w | STORAGE: SSD 120GB PQI +  6TB HDD | COOLER: Thermaltake: Water 2.0 | CASE: Cooler Master: HAF 912 Plus |
https://linustechtips.com/topic/224276-weird-problem/
How big is said file?
Are you on NTFS or FAT-32?
perhaps a quick way to delete it would be to download and create a live ubuntu disk, locate your file on disk and remove it from there.
https://linustechtips.com/topic/224276-weird-problem/#findComment-3072261
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
https://linustechtips.com/topic/224276-weird-problem/#findComment-3072288
Thx, will try it now. If it doesn't help, then I will try the other method @Altecice suggested.
https://linustechtips.com/topic/224276-weird-problem/#findComment-3072322
I'm 100% certain it will fix the problem, I have never had it not work. :D I think I have used the program for 6 years now? Been a long time, half the time I just let it delete files for me. It is quicker than windows deleting them. :)
https://linustechtips.com/topic/224276-weird-problem/#findComment-3072339
Damn. I'm unable to download it. Both Chrome & Firefox blocked it, saying it contains virus.
https://linustechtips.com/topic/224276-weird-problem/#findComment-3072357
It's not a virus lol. It's on cnet. You should be able to let it download anyways? Try cnet and see if that will install, that first link may have been the wrong site. I can't remember what the original site for the program looks like. But if it says it is still a virus from cnet chances are it is because it modifies windows. Just a false positive.
https://linustechtips.com/topic/224276-weird-problem/#findComment-3072369
Thx, it worked. Thank you mate :)
https://linustechtips.com/topic/224276-weird-problem/#findComment-3072404
No problem. :)
https://linustechtips.com/topic/224276-weird-problem/#findComment-3072410
