The PC I have is over 7 years old so I can say without a doubt I need a new one. I want to build one that can handle Dark Souls and Dark Souls 2 on max settings along with some other games I may play as well such as Skyrim, the new Gauntlet, maybe D3, and hopefully Demon's Souls if they ever decide to put it on steam. Here are the parts I'm going with:
Graphics card: GTX 760 or R9 280X
CPU: FX 8320
Motherboard: GIGABYTE GA-970A-UD3P
RAM: 8gb
HDD: 1tb
SSD: 128gb
PSU: SeaSonic M12II 620
Tower: Rosewill R5
I want to ask others who are pc building savvy if I made the right choices for a great PC at a reasonable cost.
https://linustechtips.com/topic/224125-building-a-pc/
1 x Seagate Barracuda 7200.14 1TB, SATA 6Gb/s (ST1000DM003)
1 x Crucial MX100 128GB, SATA 6Gb/s (CT128MX100SSD1)
1 x Intel Core i5-4460, 4x 3.20GHz, boxed (BX80646I54460)
1 x Crucial Ballistix Sport DIMM Kit 8GB, DDR3-1600, CL9-9-9-24 (BLS2CP4G3D1609DS1S00)
1 x ASUS R9280-DC2T-3GD5 DirectCU II TOP, Radeon R9 280, 3GB GDDR5, 2x DVI, HDMI, DisplayPort (90YV0620-M0NA00)
1 x ASRock H97 Pro4 (90-MXGUH0-A0UAYZ)
1 x LG Electronics GH24NSB0 black, SATA, bulk (GH24NSB0.AUAA10B)
1 x EKL Alpenföhn Brocken ECO (84000000106)
1 x Nanoxia Deep Silence 3 black(NXDS3B)
1 x be quiet! Straight Power E10 400W ATX 2.4 (E10-400W/BN230)
all around around 750$
for gaming you don't need more than four cores on a CPU, however if you render a lot or use photoshop, then i would recommend more cores
https://linustechtips.com/topic/224125-building-a-pc/#findComment-3070052
https://linustechtips.com/topic/224125-building-a-pc/#findComment-3070237
Thank you so much!
https://linustechtips.com/topic/224125-building-a-pc/#findComment-3070273
I found most of the items on newegg but a few I didn't likw the case and cpu fan.  Some of those items looks european and I live in the United States if that makes it harder to pick things. :(
well, the case is pretty much always personal prefernce, the only thing you have to look is, if your motherboard and your cpu cooler fits in. Instead of the CPU fan you can take a be quiet! Cooler for around 40-50$. Here is the case on amazon: http://www.amazon.com/NANOXIA-Silence-schwarz-Gehaeuse-Tower/dp/B008J1I0I6/ref=sr_1_1?ie=UTF8&qid=1411947994&sr=8-1&keywords=Nanoxia+Deep+Silence+1
https://linustechtips.com/topic/224125-building-a-pc/#findComment-3071286
