Razer Green Switches
Go to solution Solved by Damikiller37,
I own a Cherry MX Brown keyboard and I have tried the Razer Green switches in store and they felt pretty good but I would disagree and say that MX Browns had more of a feedback than them. For me they felt really similar to MX Blues and that is what they are supposed to replace so I don't know why Razer even bothered and if a minimal difference between them was worth their effort.
EDIT: Also G710+ has an O-ring mod so that could have made the MX Browns feel more mushy than normal.
So I was at Best Buy earlier and tried out a couple of mechanical keyboards. I tried the G710+ which I thought I'd really like with the brown switches, it turned out they felt mushy like a membrane. It wasn't satisfying at all and didn't have any feedback. Then I tried the Black widow Ultimate and love the switches. I'm just worried about quality control because they're made in China. So what are the Cherry equivalents? And what are some keyboard recommendations? I'd prefer a 10-key but it doesn't matter. Thanks.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/223588-razer-green-switches/
Just buy blues. Thats basically what they are. Razer products tend to break, at least for me.
As for quality control, I wouldn't be surprised if it is very good.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/223588-razer-green-switches/#findComment-3062987
Blues are the Cherry counterparts to Razer "Greens". I would get Blues, since they're manufactured in Germany.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/223588-razer-green-switches/#findComment-3062996
https://linustechtips.com/topic/223588-razer-green-switches/#findComment-3063001
They're cheaper to buy than Cherry ones. The G710+ they had on display had no tactical feedback at all I don't know why.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
https://linustechtips.com/topic/223588-razer-green-switches/#findComment-3063018
Never had  a Razer product break on me but they're not the best quality.
Buy a Corsair k70 with some blues and you're good
https://linustechtips.com/topic/223588-razer-green-switches/#findComment-3063020
I've heard that K70's LEDs die pretty often. Is this true?
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
https://linustechtips.com/topic/223588-razer-green-switches/#findComment-3063028
Well, if your not buying the new K70 RGB They'll eventually die. Considering all of the implementations of LEDS on mechanical switches were the same until recently.
Non have died on my Razer Blackwidow (2013 edition, Cherry MX Blues)
I haven't heard that before though, so im not sure. But I would say that it would be equally likely that they would die on any mechanical keyboard
https://linustechtips.com/topic/223588-razer-green-switches/#findComment-3063039
As Damikiller had stated, the G710+ comes with orings installed, when you depress the key all the way down, the oring dampens the impact when you bottom out. Some like it, I don't as it makes it feel even mushier.
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
https://linustechtips.com/topic/223588-razer-green-switches/#findComment-3063815
So, a normal brown switch isn't that mushy?
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
https://linustechtips.com/topic/223588-razer-green-switches/#findComment-3064993
