sleeved cables?
Go to solution Solved by scaryjam823,
what kind of solder?
Just your standard solder with flux? What I meant was solder new wires in the middle to lengthen the cable. I done the opposite to shorten mine where I needed to.
i have an NZXT phantom and the front USB and audio cables are hardly long enough, so i need some extendors for both but all i can find are the bitfenix they arnt bad but i cant find a sleeved black, only hard black or blue and the blue would stick out really bad, what are some other options? id like to keep it under $15 each. thanks guys and gals!
https://linustechtips.com/topic/221115-sleeved-cables/
Cut the wires, solder a piece in the middle to increase the length to where you need it. Sleeve it and done. Or cut it somewhere behind the panel where it wont be seen.
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
https://linustechtips.com/topic/221115-sleeved-cables/#findComment-3031186
https://linustechtips.com/topic/221115-sleeved-cables/#findComment-3031208
