My family needs to get a new camera, preferably a DSLR. Our current one is going to shit and our video camera, even though its only 3 years old, sucks ass at shooting videos. We need a camera that can fulfill these requirements inbetween the 500-600 cdn dollar range. Any suggestions?
CPU intel potato2 | Motherboard xpotato69 | RAM DDRPotato | GPU potato 6969 Ti | Case potato curbiide | Storage WD potato GB grey | PSU lakesonic 69 potato Watts | Display(s)69" 0.5K potato 69*69 | Cooling 4 heatpipe fried potato | Keyboard 69 key potato switches | Mouse yukon gold potato | Sound 6.9 surround potato | Operating System OS69 potato
CPU I7 5700HQ |  RAM 8gb DDR3 | GPU GTX 960M | Storage 1 TB HGST HDD | Display 15.6" 1080p IPS panel | Keyboard Steelseries RGB | Operating System Windows 10
CPU R7 3800x |  RAM 32 GB 3200MHZ DDR4| GPU RX 5700XT Ref. | Storage 1TB m.2 NVME, 2x 500GB SSD, 4TB and 750gb hdd | Display LG 32GK850F-BKeyboard Aorus K7 with reds | PSU Corsair RM750X | Case Corsair 275R | Operating System Windows 10
https://linustechtips.com/topic/221114-need-a-dslr/
http://store.sony.ca/a5000-mirrorless-camera-w-16-50mm-lens-zid31-ILCE5000L//cat-31-catid-All-a5000?vva_ColorCode=BC008&_t=pfm%3Dcategory
Compact DSLR. With changeable lenses. (It actually has a translucent single lens)
$500 CAD
Exmor Sensor
E - Mount Sony Lenses. (And they sell adapters for the bigger lenses)
5800X3D - RTX 4070 - 2K @ 165Hz
https://linustechtips.com/topic/221114-need-a-dslr/#findComment-3031181
I recommend going to costco and getting either a Canon rebel SL1 or a T4i/T5i or similar Nikon (D3200 or 5200 iirc) and trying it out. You get 90 days and can get a real feel for the camera.
proud owner of alienware 13 with graphic amplifier and also a alienware X51 gaming PC!!! really powerfulL!!
xoxo samantha <3
https://linustechtips.com/topic/221114-need-a-dslr/#findComment-3031203
That's not an SLR my friend.
xoxo samantha <3
https://linustechtips.com/topic/221114-need-a-dslr/#findComment-3031207
if video is important than I recommend the Canon t3i.  The Nikon d3300 or 3200 are also great cameras but Canon does video better.
I use a Nikon D5300 for video work in addition to still photography.
http://linustechtips.com/main/topic/216807-for-people-just-getting-into-photography/
I do recommend reading though the begging of that thread though to decide if you actually need a DSLR or if a cheaper option will work for you.
01010010 01101111 01100010  01001101 01100001 01100011 01010010 01100001 01100101
https://linustechtips.com/topic/221114-need-a-dslr/#findComment-3031212
Oops... (While the whole point was a SLR, minus the Lens and bulk)
Well. Technically most Sony cameras only have the Mirror for the light sensors.
And they are not going to be like professionally doing things.
But it still has an Exmor Sensor (What Canon and Nikon use) and flash, 1080p video, tilt screen, and changeable lenses. (And better processor and engine)
https://linustechtips.com/topic/221114-need-a-dslr/#findComment-3031223
Nikon
D3100 and up or D5100 <-- you cab find the last gen ones for very cheap on kijiji. and they are almost just as good
these are very good DSLR for people who are starting out. and also come with a descant kit lens (18-55mm)
Canon
T3i or higher
just as good for photos as the Nikon. but much better for video because of things like mic input and more options to play around in the setting for video. but watch out because some of these canons don't have continuous auto focus while in video recording . but almost all nikon DSLRS have the Continuous AF.
do some research and post back here to get some opinions .
i got my nikon D3100 for less than $200CAD(from kijiji) with lens and a bag. and its as good as new. guy never used it. so you might be able to find something like that.
https://linustechtips.com/topic/221114-need-a-dslr/#findComment-3031474
this is a good deal but if you are willing to spend that kind of money why not get a higher end last gen model. nothing much have changed since and nothing that you will actually feel.
try to find a used(in good condition) D5200 or somthing alone those lines. much better than the D3xxx series
https://linustechtips.com/topic/221114-need-a-dslr/#findComment-3031498
Buy a last gen product?! Ew lol
Actually that's not a bad idea either although technically the D3300/5300 has a slightly better image sensor
https://linustechtips.com/topic/221114-need-a-dslr/#findComment-3031823
Thanks for all the replies. We were gonna get a t3i but they were all sold out so we got a refurbed t5i for 629.
https://linustechtips.com/topic/221114-need-a-dslr/#findComment-3032033
slightly better..
but the differance between the D3xxx and D5xxx is much larger... and more significant
https://linustechtips.com/topic/221114-need-a-dslr/#findComment-3032269
Actually the sensor in the d3/5300 and the d3/5200 are the same.    The d3/5300 does not have a low pass filter and uses the expeed 4 processor.
The improvements in image quality and features are a result of the new sensor and removal of the low pass filter.
https://linustechtips.com/topic/221114-need-a-dslr/#findComment-3032710
