Hi guys so soon I will be building my own pc and I can't remember if the case comes with a IO shield or not or if the motherboard does and I was wondering if it did will the case be ok for the motherboard.
Theses are my components
Asrock H97 Pro4
Titanium 500 ATX PC Gaming Case
Thanks
https://linustechtips.com/topic/221063-will-it-fit/
The motherboard comes with the IO Shield, and it will fit. Though, the case looks particularly crap.
https://linustechtips.com/topic/221063-will-it-fit/#findComment-3030408
there are better cases for that money ^^
5.1GHz 4770k
My Specs
Intel i7-4770K @ 4.7GHz | Corsair H105 w/ SP120 | Asus Gene VI | 32GB Corsair Vengeance LP | 2x GTX 780Ti| Corsair 750D | OCZ Agility 3 | Samsung 840/850 | Sandisk SSD | 3TB WD RED | Seagate Barracuda 2TB | Corsair RM850 | ASUS PB278Q | SyncMaster 2370HD | SyncMaster P2450
https://linustechtips.com/topic/221063-will-it-fit/#findComment-3030431
