Hello Everyone
I live in a country that ambient temperatures is goes from 30-42 C all year
I just made this build
http://pcpartpicker.com/p/nr9ZWZ
But im stock with the cooling system,My case include 1x200mm + 2x140mm fan,
What do you recommend for cooling? CPU and GPU
taking in consideration my 42 C ambient temperature
Thanks for your replays
https://linustechtips.com/topic/220214-help-with-custom-cooling-system/
If you are taking about closed loop liquid coolers then you have a wide selection. 240mm and bigger would be a good choice.
Air cooling is also an option. A large tower heat sink is a good idea.
The other option is a custom water cooling setup with cpu and gpu blocks.
Corsair 750D | Asus Crosshair V Formula-Z | FX 9590 | Kingston HyperX 16GB@1866MHz | MSI R9 290X Lightning | Seasonic 1050W Platinum | 2x WD 3TB Green HDD | Samsung 840 Pro 256GB SSD | Crucial 512GB SSD
Alphacool XT45 360mm | Alphacool Monsta 280mm | Silverstone AP121 | Silverstone AP141 | EK Supremacy Elite | EK ASUS C5F-Z | EK R9-290X Lightning | EK 3/8-1/2 Nickel | XSPC D5 Acrylic Tank | Primochill 3/8-1/2
thanks for your reply
Do you know a place where i can get a compatible GPU cooler for my msi 970 gaming 4?
If you want to get a custom loop you can look at EK for water blocks but if you want a AIO liquid cooler for your graphics card the best option would be to get the NZXT G10 adapter and a compatible AIO liquid cooler and cool it that way.
More info - NZXT G10 http://www.nzxt.com/product/detail/138-kraken-g10-gpu-bracket.html
You're likely going to run into problems with that GPU, a vast majority of water blocks are designed for use with reference cards, fairly confident the MSI GTX 970 is not a reference design. You would need to contact the block manufacturer to confirm that if you got one, it would be compatible.
Aside from a completely custom loop you could look into the Swiftech h220x. I would add an additional radiator to the loop if you were going to throw the GPU on it as well.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
