Hello, everyone! Time for a new PC! I'm a little nervous since this is my first build, but I have you people ;) , now I was wondering if all these parts are  gonna work together. Or if i should change parts for others ect.
Thanks!  :D
CASE: Fractal design define r4
PSU: Corsair cx600m
CPU: Intel core i5 4590
GPU: XFX Radeon 270x 2GB
RAM: Crucial DDR3 BallistiX 8GB 1600mhz
SSD: Kingston SSDNow v300 120gb 2,5
MOBO: MSI Z97 G43 Socket 1150
OS: Windows 8,1 64bit
https://linustechtips.com/topic/219510-ready-or-not/
Thanks!  :D
PSU: Corsair cx600m
Yeah, it'll work fine. Nice build!
https://linustechtips.com/topic/219510-ready-or-not/#findComment-3009013
Welcome to the forum! Please remember to follow your topics so you're notified when someone answers ;) in my sig you can find links to the CoC and the forum's F.A.Q. check them out!
As a general rule you should also point out what you're going to do with your pc, it's very important. For now i can tell you for sure that you don't need a 600watt psu, not even close. 500watts should be more than enough for that build. Also, the v300 doesn't perform very well, so you should get a samsung 840 evo (for example) instead. Don't bother with a 270x, get a 270 and overclock it, it's the same thing.
Get back to me with your use scenario and budget and maybe I can help a bit more :)
sudo chmod -R 000 /*
https://linustechtips.com/topic/219510-ready-or-not/#findComment-3009015
Mmmh. Good build but could you stretch the budget a bit and get an R9 280 instead? It will give you much, much better mileage specially if you overclock it.
"Fighting for peace is like screwing for virginity"
- George Carlin (1937-2008)
https://linustechtips.com/topic/219510-ready-or-not/#findComment-3009034
