Afternoon all/Morning Yanks,
My rig gets stuck on the Gigabyte POST screen almost everytime I turn my rig on now. Its fine once I press restart but after powering off and turning on again I get the problem again. Does anybody have any idea what this is? My rig specs are in my profile...
https://linustechtips.com/topic/219477-stuck-on-post/
What do you mean by stuck?
Have you tried clearing the CMOS?
https://linustechtips.com/topic/219477-stuck-on-post/#findComment-3008701
It just stays on the Gigabyte screen and won't go to Windows.
I've not no but I shouldn't need to as nothing has changed/tinkered with and the rig isn't OC'ed.
Try doing that anyway... Then disconnect all storage devices and see if the "No boot device detected." or something similar comes up...
I've had my Gigabyte board go bad when I switched PSUs... A simple CMOS reset fixed the problem...
https://linustechtips.com/topic/219477-stuck-on-post/#findComment-3008721
I would like to add that you can also try Totally ressetting the bios on a gigabyte board by holding to power button for 30 seconds. The backup bios will replace the default bios.
had the same problem on a gigabyte h61 board and a celeron
Hello fellow OC3D'er. ;)
https://linustechtips.com/topic/219477-stuck-on-post/#findComment-3008760
I did not know about that...
Does this work with all Gigabyte motherboards? And will it work using the front I/O power button?
https://linustechtips.com/topic/219477-stuck-on-post/#findComment-3008765
All gigabyte motherboards with dual bios have this (i think it started in 2005)
edit: yes it works with the fromt i/o button
when bios gets corrupted it should automatically flash the bios from the backup chip onto the main chip, but it does not always work so manual flash is needed
Hey!
https://linustechtips.com/topic/219477-stuck-on-post/#findComment-3008778
