I want to buy a corsair H100i to put in my Corsair 300r case and want to be 110% sure it will fit with a Maximus VI Hero Motherboard and Vengeance Pro RAM before I buy it.
Does anyone have the same setup in use?
I also don't want to mod my case or any components.
"Since the Internet is almost diametrically opposed to the notion of Quality Control, in recent years it's been a lot easier to just assume everything's s**t until it can prove itself otherwise".  Ben "Yahtzee" Croshaw (2008)
https://linustechtips.com/topic/219259-will-it-fit/
natively, no it does not. because of the proximity of the mobo and roof, the H100i
and fans are a problem. only solution is modding the roof.
https://linustechtips.com/topic/219259-will-it-fit/#findComment-3006318
