what?
Both boards are a fire hazard :(
http://www.overclock.net/t/946407/amd-motherboards-vrm-info-database
I cant spend 100$ on MB lol
I understand, but I'm sure you wouldn't want your new rig to die 3 weeks after you build it :(
https://linustechtips.com/topic/218674-help-me-choose/#findComment-2998851
so those 2 MB'S are that bad??
What abouthASUS M5A97 LE R2.0
https://linustechtips.com/topic/218674-help-me-choose/#findComment-2998899
Much better board :)
Not massive VRM counts but unlike the others they aren't documented to fail.
https://linustechtips.com/topic/218674-help-me-choose/#findComment-2998909
