Hey guys, I am working on a build that is copper colored, and I am ready to paint my Mobo's cover and my GPU is ready to be painted as well with it's cooler and backplate, and I have RAM that fits the theme, but I was wondering where are the Copper Tower coolers? I mean Copper is more expensive and I am fine with that, but it is also better at cooling. Anyone know one that is copper becuase I can't find one. I don't really need great performance either, It just has to keep 3930k under 70 at load at 4.4GHZ, so a decent tower should be able to do.
https://linustechtips.com/topic/21701-copper-air-cooling-tower/
the thermalright ultra extreme copper might be what your looking for, where to buy one im not sure off hand but i have seen them before their pretty cool
Edit: though last time i saw one was a few years ago so you might not be able to find one and it may not eve have 2011 socket support but its the only copper cooler i can think of
https://linustechtips.com/topic/21701-copper-air-cooling-tower/#findComment-266653
Prolimatech Super Mega variation of their Megahalems got only copper pieces, and I know that you're not looking for such thing, but anyway just wanted to contribute some info.
*Not my picture, found in google*
//Edit: Found something from Scythe, check it out.
https://linustechtips.com/topic/21701-copper-air-cooling-tower/#findComment-275901
Thanks for the link in the Edit. I guess I will have to modify the mounting hardware because that thing is from like 5 years ago. Thanks!
https://linustechtips.com/topic/21701-copper-air-cooling-tower/#findComment-278457
Ok this may not be exactly what you are looking for but if you are having trouble finding exactly what you want this may be a good compromise plus it is a killer performer rating in lockstep with the noctua Dh 14
http://www.newegg.com/Product/Product.aspx?Item=N82E16835709003
Its orange but is a bit of a metallic burnt orange that might be able to fit what you are doing.  Also if you really wanted too you could repaint the very top fins to match more what you want and the other fins should blend in with the fans covering part of them up anyway.
Phanteks PH-TC14PE_OR
https://linustechtips.com/topic/21701-copper-air-cooling-tower/#findComment-287590
Here is another suggestion as well.  Get one of these dark rock Pro 2's and repaint the top plate.  That I think would actually look really killer.  What you could do is mask off the end caps for the pipes and keep them black and repaint the plate itself a copper.  That could look pretty sick.
https://linustechtips.com/topic/21701-copper-air-cooling-tower/#findComment-287618
