https://linustechtips.com/topic/216698-will-this-build-work/
Yes, it's all compatible.
Little point getting a z97 board if you're going to get a locked i5 though.
The blue ram and red motherboard is also pretty awkward.
https://linustechtips.com/topic/216698-will-this-build-work/#findComment-2970252
Z97 is still the smart move if getting an Nvidia gpu so you can SLI.
Although, I also wouldn't be getting a 760...
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/216698-will-this-build-work/#findComment-2970263
all works, yea cpu thing everyone else is saying above me, if you don't plan on overclocking ever dw, get an SSD also if you can
Yes Yes Legalize Gay Marriage sure, but have you ever considered Weaponizing Gay?
CPU: I5 4690 3.5ghz || MOBO: MSI B85-G43 Gaming Board || RAM: 8GB Corsair Vengance Pro - Red || GPU: Gainward GTX770 Phantom 4gb || PSU: EVGA SuperNova 750W Gold || Case: Thermaltake Urban T31 || SSD: Corsair Force 120GB || HDD: 1TB WD Black
https://linustechtips.com/topic/216698-will-this-build-work/#findComment-2970268
yes but you don do allot better
budget?
location?
uses?
please read before posting
http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/
use the quote button if you want my help
Specs
https://linustechtips.com/topic/216698-will-this-build-work/#findComment-2970272
The 600B isn't exactly optimal for a 760 sli.
https://linustechtips.com/topic/216698-will-this-build-work/#findComment-2970282
It should still be able to run it.
Anyway, its still a reason to consider going with a Z board even if not overclocking.
PSU Tier List | CoC
https://linustechtips.com/topic/216698-will-this-build-work/#findComment-2970331
