Hi, I have recently updated my BIOS to F10B and when I did I was seeing some problems with the BIOS interface (I don't know about functionality). First I saw that some of the options in the BIOS that were there before now aren't for example Host/PCIe Clock frequency and processor base clock. Also on the top of the interface it no longer says UEFI DualBIOS it just says UEFI BIOS. I was wondering if there was any way to revert back to an older bios setting like F7. I have tried using @BIOS and it says " This motherboard is protected from using this BIOS.". I have also tried Q-Flash but I still can't downgrade to F7. I have attached pictures of my BIOS screen and motherboard info.
post-46623-0-85160700-1410916261_thumb.j
post-46623-0-20307100-1410916265_thumb.j
post-46623-0-47798600-1410916268_thumb.j
https://linustechtips.com/topic/216679-bios-problem/
I might be missing something, but what is the problem? B)
The problem is that there are missing sliders on the menu after updating and it no longer says DualBios and I was wondering if there was a way to downgrade BIOS version. Here is a pic of what it should look like.
https://linustechtips.com/topic/216679-bios-problem/#findComment-2969999
I still don't see your problem. BIOS updates, as any other update, change things. Smaller things like naming etc. don't mean anything in performance and usage. As for CPU base clock and ratio, they are set to auto. Set them to manual and I guess you will see the sliders. I'm still running with F7 (and using legacy interface) so I can't give more detailed help on that.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/216679-bios-problem/#findComment-2973366
