Hello, so i just installed Eos on my laptop and i was hopeing i can change the way i get the @ symbol. it is now shift + 2 = @, but i want it to be altgr + 2. is there a way i can do that?
Change your keyboard type. There is an option on installation, I'm not sure about how you change it after installation but it will probably be in settings somewhere.
https://linustechtips.com/topic/216525-elementary-os-problem/#findComment-2967603
key bindings also if you get the chance to try voyager os
Steve
https://linustechtips.com/topic/216525-elementary-os-problem/#findComment-2967604
