Problems solved, HyperX question.
Go to solution Solved by ShearMe,
Do you have any USB hubs plugged in (including monitors and keyboards)? They sometimes cause various issues.
I would recommend switching to the HyperX Cloud if we can't solve this issue eventually. Analog means no software issues.
EDIT: I've now bought a HyperX Cloud headset as I found it cheap on ebay. Now my question is if my motherboard will provide a good sound quality or if I should get a dedicated soundcard or a DAC?
Intel Core i5 4670
Windows 7 Home Premium 64-bit
8.00GB Single-Channel DDR3
ASUS H87-PLUS
2047MB GTX 660
https://linustechtips.com/topic/215925-problems-solved-hyperx-question/
Here is a list of all peripherals in USB ports.
  • Keyboard
  • Mouse
  • External hard drive (has own power cord)
  • TrackIR (not always on)
