I'm thinking of building a new computer to do some small gaming on ( Call of duty WaW, Skyrim, maybe some new titles on low settings ) But I don't know what to go with, AMD or Intel?. I've got two XFX Radeon 6850's that I want to run in crossfire, The builds will show you my budget. ( Around £175 ) ( all I need is a case, cpu, ram and motherboard )
AMD : http://uk.pcpartpicker.com/p/Q42KsY
Intel : http://uk.pcpartpicker.com/p/JgHvD3
If you have any better solutions or reccomendations please tell me in the comments, Thanks!
https://linustechtips.com/topic/215463-can-anyone-help-me/
Go with the G3258, and 8gb of Ram. You should also go for either a Z97 board from any manufacturer or an Asus h81 board.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/215463-can-anyone-help-me/#findComment-2950644
Go for the intel one, might want to swap out that motherboard and go for some different ram though.
CPU: i5 4670k / Cooler: Corsiar H100i / RAM: 2x4gb Corsair Vengeance Pro 1600mhz / Motherboard: MSI Z87-G45 GAMING / GPU: Asus r9 290 DirectCUii / Case: Define r4 / Storage: 128gb Samsung 840 EVO & 2tb Seagate barricuda / PSU: Corsair RM750
https://linustechtips.com/topic/215463-can-anyone-help-me/#findComment-2950669
