DHS is generally higher binned, but unless the price difference isn't a large one, don't bother. They may OC better.
https://linustechtips.com/topic/214808-double-hand-selected/#findComment-2939644
Double Hand Selected= the chip of the GPU especially selected and it's a better chip then the normal one.
I know that some high end GPUs like that found in the AMD R9 290x2 AresIII is cherry picked ... Never heard of double cherry picked. I really don't care either cause allot of times the cherry picked chip perform the same anyway.
https://linustechtips.com/topic/214808-double-hand-selected/#findComment-2939706
The Inno3D has that GTX 780 iChill HerculeZ X3 Ultra DHS Edition and a 780 Ti whit a DHS Chip.
https://linustechtips.com/topic/214808-double-hand-selected/#findComment-2939760
