Help for a good monitor!
Solved by brownninja97,
before we get on the monitor response time issue again your brain has a 7ms delay, this is according to the olympics ruleset(if you begin to run under that time in a sprint then you are considered a cheater), thats for runners that train their reaction time to be extremely fast, honestly i think if its under 10ms latency you are fine, you will just placebo effect about everything.
As for monitors i like the dell ultrasharp series of monitors
As i hate TN panels i will not link one, im sorry but they are very bad in quality terms.
IPS and VA all the way
