Graphics Glitching On Youtube? ***NEED HELP***
I have an R7 265 and am currently having very weird graphics problems when on Youtube..
I have to displays connected, one Acer monitor via DVI and one Vizio 46 inch TV via HDMI
I usually run Youtube on the TV and recently, when ever i click a video, this happens to my Acer:
imgur.com/N7EbgzW
This only happens on Youtube. I have to either put it in hibernate or shut down and restart to fix it buy i want to know the cause, i am almost certain I have the most updated drivers installed and dont know what is going on.
https://www.youtube.com/watch?v=KqO9cmMhhQM
https://www.youtube.com/watch?v=3W43Cc3_zo8
Sometimes when i exit the video it goes back to normal but sometimes the Acer screen turns white and flashes EXTREMELY fast.
If any other info is needed please ask
I HAVE TRIED REINSTALLING FLASH AND TRIED USING DIFFERENT BROWSERS AND NOTHING
I Love Playing CS:GO!
Current
AMD Athlon X4 760K | MSI A78M-E45 | Sapphire R7 265 | Cougar Solution | Cooler Master Hyper T4 | ADATA XPg V1.0 1600Mhz 8GB | Fractal Design 650W
https://linustechtips.com/topic/214617-graphics-glitching-on-youtube-need-help/
Try using HTML5 instead of Flash, it is somewhere in the options if you use Chrome 32 i believe.
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
I swear this thread was posted earlier today.....
Edit:
Now yesterday as I'm in Aus.... quarter past 12, been on LTTF since 11am.
Maybe I should go to sleep......
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
I experienced some glitches on YouTube with my laptop once, and it was right after I changed the refresh rate of my monitor. If it is a video display problem, this is one of the possibilities. If you are able to try out different refresh rates, try a few options and see how it helps.
Most use HTML5
Current
My monitor is only 60Hz
Current
Hi
Sadly, it's your GPU :( I have bought a brand new Gigabyte r9 280x windforce3 REV: 2.0 and all I had from that card is just problems!
I don't know if you can but, if I were you, I would return that card!
I think it was my driver! I updated it because the Sapphire site wasnt updated :( so i went on the AMD site and got 14.4 catalyst :D no issues so far!
Sadly, It has begun happening again
Current
This happened to me once but it was because my graphics card wasn't snapped into my PCI slot and it came loose. I had been using on-board graphics for 3 weeks... I was such a computer noob back then *sighs and reflects on his past*
CPU: Intel i5-2400 Mobo: ASUS Maximus IV Gene-Z RAM: 8GB G.Skill DDR3 1333MHz GPU: Sapphire R9 280x Tri-X Case Corsair Obsidian Series 350D PSU: EVGA 500w 80+ Certified
Guys, it happens when i hit a YT video on either monitor. Not just TV
Current
