Please help. How do I activate Quick Sync?
Solved by Faa,
It's detected when I take my GPU out of the MOBO But after I set the Quick Sync on and put the GPU back the iGPU disables and is not detected again.
Disable IGP multi-monitor. It's been to long since I touched a platform with the intel IGP.
thedood2k ·
Posted in Power Supplies1 -
DARTHDIVIDER0213 ·
Posted in Troubleshooting8 -
1
Xx-albinos-xX ·
Posted in Troubleshooting10 -
2
_Darasuum_ ·
Posted in Power Supplies6 -
1
4
play_circle_filled
Latest From ShortCircuit:
