Help on locating a good case
Go to solution Solved by sid0195,
Hi!
When I first built my pc, I decided to save some money buy putting my build into my dads old pc case. Its not very appealing, has bad airflow, no way to watercool, and I would like to upgrade to something a little more professional.
Im looking for a good case that is black, and can use 2 optical drives. In terms of budget, 150$ or less. Im having a hard time finding a good one, so hopefully one of you can help.
Thanks!
EDIT: In *case* it matters,  for size/cooling or whatnot, specs are : evga gtx 770 acx, i7-4771, 16gb 1600 ram, and semi-modular coolermaster v650 psu, m-atx mobo
https://linustechtips.com/topic/213561-help-on-locating-a-good-case/
Probably a lot of people are gonna recommend the fractal design R4 blackout or a lot of the corsair cases. If those don't fit your liking I'm afraid you're gonna have to be a bit more specific on what you want.
CP: Ryzen 7 2700x | Motherboard AsRock B450M | RAM 32GB Corsair ddr4 | GPU EVGA (RIP) 1070ti | Case Corsair Vengeance C-70 Black | Storage 512gb Samsung NVME ssd | PSU EVGA 850w Platinum | Display Asus PB258Q 1440p
| Cooling Noctua NH D15 | Keyboard Cooler master mechanical kb with blue switches | Mouse Logitech G502 | Sound Beyerdynamic DT 990
| Laptop Maingear Vector Pro 2 (Ryzen 9 6900xh, Nvidia 3070t, 32gb ram)
Corsair, Phanteks, NZXT, Fractal design are the ones to look for.
Lol. I didnt expect to find a good one this quickly. This one checks off pretty much everything on my list. thank you all for your help, I really appreciate it! :)
If you ever need help with cases ask me.....ive been through so many threads, watched so many vids......its not natural D:
