So I have been carefully planning my build for like the past year (this is the time i decided I want to get serious). I would like the "PC Masters" if you will, constructive criticism of my build :) so lets start
Case: Cooler Master Storm Stryker
CPU: AMD FX8350
GPU: EVGA Geforce GTX 780 SC w/ ACX
Motherboard: Asus Sabertooth 990FX R2.0
PSU: Corsair RM 750w 80 Gold+
Memory: 16GB Corsair Vengeance Blue (1600MHz)
HDD: Western Digital Black 3TB
SSD: Samsung 840 EVO
Cooling: Corsair H100i
While we are at it, I guess i'll give you my peripherals
Mouse: Razer Deathadder 2013 Edition
Keyboard: Razer Blackwidow Ultimate 2013 Edition
Mousepad: Razer Goliathus Control Edition Mousepad (Medium)
Headsets: Razer Kraken 7.1
Monitor: *Still not sure, deciding between 1440p and 1080p (leaning a bit more to 1080p)
https://linustechtips.com/topic/212901-1800-build-thoughts/
@Crvfts Please put your items on pcpartpicker so we have a basis for your "$1800" build. Personally, I'll go with the Intel platform.
My Current PC Codename: Scrapper
Intel i5-3570 | Some LGA 1155 MOBO Some Generic DDR3 8GB 1600Mhz | PowerColor RX 560 2GB | Recycled HP Case Crucial MX100 128GB 1TB WD Blue 7200RPM | Some Generic 500w PSU | Intel Stock Cooler
https://linustechtips.com/topic/212901-1800-build-thoughts/#findComment-2891140
snip
In an $1800 build you should NOT be using an AMD CPU.
CPU: Intel i7 4770k w/Noctua NH-D15, Motherboard: Gigabyte Z97 Ultra Durable, RAM: Patriot 8Gb 1600Mhz (2x4Gb), GPU: MSI R9 390x Gaming,
SSD: Samsung 840 EVO 1Tb, HDD: Caviar Black 1Tb, Seagate 4Tb Hybrid, Case: Fractal Design Define R4, PSU: Antec Earthwatts 750w
Phone: LG G2 32Gb Black (Verizon) Laptop: Fujitsu Lifebook E754 w/ 1TB Samsung 840 Evo SSD Vehicle: 2012 Nissan Xterra named Rocky
https://linustechtips.com/topic/212901-1800-build-thoughts/#findComment-2891182
I can't see it. Copy the permalink located on the top left of your build. :)
https://linustechtips.com/topic/212901-1800-build-thoughts/#findComment-2891401
For $1800 here
*snip*
Use BBCode bro :D
https://linustechtips.com/topic/212901-1800-build-thoughts/#findComment-2891404
Also, is the peripherals included in your $1800 budget @Crvfts?
https://linustechtips.com/topic/212901-1800-build-thoughts/#findComment-2891428
CPU: AMD FX8350
Here
CPU: AMD FX-8320 3.5GHz 8-Core Processor  ($149.99 @ Newegg)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($94.99 @ NCIX US)
Motherboard: Gigabyte GA-990FXA-UD5 ATX AM3+ Motherboard  ($159.99 @ Newegg)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($109.99 @ Micro Center)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($99.99 @ Newegg)
Keyboard: Razer BlackWidow Ultimate Wired Gaming Keyboard  ($119.00 @ Mechanical Keyboards)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($53.50 @ Amazon)
Headphones: Sennheiser HD 429 Headphones  ($52.99 @ Adorama)
Other: ModMic 4.0 ($49.95)
Total: $1847.16
Generated by PCPartPicker 2014-09-10 21:40 EDT-0400
And if you have the money, go all out and buy the ROG SWIFT P278Q.
https://linustechtips.com/topic/212901-1800-build-thoughts/#findComment-2891534
http://pcpartpicker.com/p/RZRFCJ there you go :P sorry I'm kind of a noob at forum pages :/ but i just added periphials and all that, before that the computer was $1500 in just parts BUT since before this I was only using tigerdirect, newegg, and amazon that is why it was a bit more money and that is what made it out to be $1800. Also I will decide if i should go with the rog monitor. I saw Linus's review on it and it looked amazing the only thing is, it costs $800 o-o
https://linustechtips.com/topic/212901-1800-build-thoughts/#findComment-2891601
Well try to reconsider these parts. :D
Video Card: EVGA GeForce GTX 780 Ti 3GB Superclocked ACX Video Card  ($598.80 @ Newegg)
Total: $1847.16
I'll criticize your build here.
1. FX-8320 is only a underclocked 8350. When overclocked there's not much of a difference between their performance.
2. In gaming, you only need 8GB of RAM. Dual channel is preferred but you can also buy a single stick then buy another in the future if 8GB is not enough
3.Gigabyte MOBOs are better IMO.
4. You can get a 780Ti instead of the 780 for raw performance but 780 is the sweet spot for single GPU perfomance.
5. Try to reconsider the Enthoo Pro since it's very noob friendly and watercool/aircool friendly.
6. GET an SSD. :D
7. Get a Sennheiser headphones and modmic instead of the 7.1. Although if you're not an "audiophile" and will practically use your headphones purely for gaming specifically FPS, get the Kraken 7.1(I own one myself)
https://linustechtips.com/topic/212901-1800-build-thoughts/#findComment-2891711
8GB of memory is sufficient for a gaming system. The build needs an ssd. WD black are not worth the premium in my opinion. Finally, an R9 290X is a better value than the GTX 780.
CPU: AMD FX-8350 4.0GHz 8-Core Processor ($179.99 @ SuperBiiz)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler ($99.99 @ Amazon)
Motherboard: Asus Sabertooth 990FX R2.0 ATX AM3+ Motherboard ($182.98 @ SuperBiiz)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-2133 Memory ($74.70 @ Newegg)
Storage: Crucial MX100 128GB 2.5" Solid State Drive ($73.99 @ SuperBiiz)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive ($99.99 @ Dell Small Business)
Video Card: Gigabyte Radeon R9 290X 4GB WINDFORCE Video Card ($493.99 @ SuperBiiz)
Case: Cooler Master Storm Stryker (White) ATX Full Tower Case ($134.99 @ Newegg)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply ($115.99 @ NCIX US)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($16.98 @ OutletPC)
Monitor: Asus PB278Q 27.0" Monitor ($469.99 @ Amazon)
Keyboard: Razer Blackwidow Ultimate 2013 Wired Gaming Keyboard ($135.99 @ SuperBiiz)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse ($53.86 @ Amazon)
Headphones: Razer Kraken 7.1 Channel Headset ($69.99 @ Newegg)
Total: $2198.43
Generated by PCPartPicker 2014-09-11 02:44 EDT-0400
https://linustechtips.com/topic/212901-1800-build-thoughts/#findComment-2892755
