  Problem Event Name:    CLR20r3
  Problem Signature 01:    wpv xap deployer.exe
  Problem Signature 02:    2.0.0.0
  Problem Signature 03:    509915fa
  Problem Signature 04:    WPV XAP Deployer
  Problem Signature 05:    2.0.0.0
  Problem Signature 06:    509915fa
already tried the regservice and unregservice files, reseted that .dll files, like the standard procedure.
oh, and fez does the same thing too.... (in the middle of the game, same CLR20r3
https://linustechtips.com/topic/212704-clr20r3-problem/
Have you got the latest versions of flash, Java, direct x, .Net framework, installed the latest Windows update?
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
https://linustechtips.com/topic/212704-clr20r3-problem/#findComment-2895190
yes, all of them.
Try running this as an administrator in cmd prompt without the quotes. " %windir%\Microsoft.NET\Framework\v2.0.50727\ngen.exe update "
If that doesn't work try opening cmd prompt again as admin and run " sfc /scannow "
Also try downloading this and reinstalling if you haven't already. (Some games may have visual redist in the game folder if you look around you may find it and use that file instead of downloading one.
If these things do not work, try giving system restore a shot. Restore back to when you know it worked and see if that fixes the problem. How old is the hard drive you are using and was it used on a previous computer then used on this one without formatting?
https://linustechtips.com/topic/212704-clr20r3-problem/#findComment-2913254
