Is ok, but the budget is really tight...
rig: i7 4770k @4.1Ghz (delidded), Corsair Vengeance 8GB 1600Mhz, ROG Maximus VI Hero, Noctua NH-D14, EVGA GTX980SC, Samsung 850 EVO 500GB, Corsair SF600, self-built wooden Case, CoolerMaster QuickFire TK, Logitech G502, Blue Yeti, BenQ GW2760HS
https://linustechtips.com/topic/212647-advice-on-build/#findComment-2888038
I know. It's my first computer so I don't want to go too high. Plus, I am still in school with no job. Budget will be tight. I just want to know if there are any parts that could be replaced with something of similar price.
https://linustechtips.com/topic/212647-advice-on-build/#findComment-2888089
They are all od gen components, i would say it is one of the most unexpensive pcs, not that isnt too high... Anyway for me is a good one... oh, the thermal paste is not needed... and maybe the fan too...
https://linustechtips.com/topic/212647-advice-on-build/#findComment-2888932
Would the parts still be alright for gaming? Not wanting max FPS on everything.. Just more than a mid laptop
https://linustechtips.com/topic/212647-advice-on-build/#findComment-2889138
You're on a really tight budget, but this seems decent.
Maybe you don't need the Hyper 212 Evo if you don't plan to overclock.
The case already includes a few fans, so maybe you don't need that extra fan.
Also if you take off the optical drive, the hyper 212 evo and the extra fan, you save a total of £39,84, wich you can use to upgrade the CPU or the GPU, but it's up to you!
About the games, if you don't max out the settings, you probably wont have a problem (if my laptop with a GTX635M, a i5 3317U 1.70GHz and 4GB of RAM can run Minecraft 40-60FPS and G-Mod, you wont have a problem).
dude what
https://linustechtips.com/topic/212647-advice-on-build/#findComment-2930956
