Need Help Fixing Xbox 360 Wireless Controller
Solved by Powerbored,
Yes, it most certainly was me! I've been going crazy trying to get this darn controller fixed
Awesome, I'm glad you decided to jump on the forums and I'm glad you like it here, it's a great community.
I had a read through the thread are you still going to try and de-solder the trigger yourself?
The reason I don't like taking jobs like this is that Iv'e never actually worked on an Xbox controller so I can't guarantee I can do the job but If you're sure you want to go ahead with soldering but you really don't want to do it yourself I might be able to help.
However if you have a friend who has even used a soldering iron just a few times, they'd probably be as helpful as me.
