Im having a problem where steam will download something and the download completes instantaneously but then continues to take hours to actually "write to disk" as it says, I have a western Digital 1tb Black harddrive in my computer, is there a reason its taking hours to write 28mb worth of downloads? I really dont understand why its doing this.
https://linustechtips.com/topic/212441-hard-drive-issues-with-steam/
I'm really sorry to hear about the issue you are facing with the WD Black.
I would maybe try a different SATA port on the mobo, this may cause slow write/read speed.
If after changing the ports the speed is still that bad, the first thing I would do is back up all important data on the drive and test it with Data LifeGuard Diagnostics (DLG): http://support.wdc.com/product/download.asp?groupid=810
It will let you determine if the problem is with the HDD. If the DLG software fails at any point of the Quick and Extended test (run both of them just to be sure) most probably your drive is failing.
And I'd suggest to contact our tech support for further assistance: http://support.wdc.com/contact/contact.asp?lang=en
Keep me posted about the test results though!
Good luck!
I hope I can help with any storage issues that you may have!  ;)
Oh snap, we have hardware reps on forums now?
post-41219-South-Park-NICE-gif-Imgur-CQw
"Rampage IV" - Gaming PC
Cooler Master HAF 932 Advanced    EVGA GeForce GTX 980                            ASUS VE278H 27in LED Monitor x 3
ASUS Rampage IV Black Edition         G.Skill Trident X 16GB DDR3 2400Mhz     Cooler Master Silent Pro Gold - 1000W
i7 4930k - Overclocked @ 4.5GHz     Samsung 850 SSD 250GB x2 RAID 0           Western Digital Blue 1TB
Logitech G930 Wireless Headset      Razer Naga 2012 MMO Gaming Mouse      Logitech G710+ Mechanical Keyboard
"EMCMS-ESXI" - Server
HPZ800 Workstation Chassis           Seagate 4TB NAS Drive x 4 RAID Z           48GB ECC Elpida DDR3 SDRAM
Xeon E5620 @ 2.66GHz x 2             PNY CS2211 240GB SSD                          HP 80 PLUS Silver APFC PSU - 1110W
LSI 9211-8i SAS in IT Mode
thats totally fine as long as they are providing appropriate help and they are not advertising
That's why we are here for, guys!
To help with whatever we can and provide appropriate solutions!   :)
