I would like to get one seeing as i now my 2nd PC is running and only have one monitor.
Would a KVM have an effect if im gaming? if so, how bad would it be?
What are some good brands?
Budget would be $60
Thanks for any feedback :)
-edit- if this is posted in the wrong area please tell me
Edited by Wingfan
Ryzen 7 5800X3D , Arctic Liquid Freezer  III , Gigabyte X570 Aorus Elite , Corsair Vengeance 32GB , Gigabyte RTX 5070Ti ,  WD SN850 / MP44L
Corsair RM 850x, LIAN LI Lancool 207
https://linustechtips.com/topic/212143-kvm-switches/
A switch should have no added latency whatsoever. They just pass through the signal I think
Case: Meatbag, humanoid - APU: Human Brain version 1.53 (stock clock) - Storage: 100TB SND (Squishy Neuron Drive) - PSU: a combined 500W of Mitochondrial cells - Optical Drives: 2 Oculi, with corrective lenses.
https://linustechtips.com/topic/212143-kvm-switches/#findComment-2879771
Uh? no why would it effect gaming? it just allows you to connect your peripherals and monitor to 2 pcs, it does not require any performance from your PC, its just a basic switch, it does no processing
Belkin make some decent ones
https://linustechtips.com/topic/212143-kvm-switches/#findComment-2879774
Wasnt sure if it would cause a latency problem.
Thanks for the feedback :)
https://linustechtips.com/topic/212143-kvm-switches/#findComment-2879812
A KVM switch shouldn't add any latency, but keep in mind that the cheap ones only come with VGA ports: The switches with DVI are more expensive
Im looking at them now and your right about the DVI ones lol and that would be the type i would want
https://linustechtips.com/topic/212143-kvm-switches/#findComment-2879944
I can't speak from experience, the only KVM switch I used was a vga one on a low res monitor. I believe that you'd have to spend at least 75$. This one seems to work: http://www.amazon.com/IOGEAR-2-Port-DVI-D-Cable-GCS932UB/dp/B002TQYSN8/ref=cm_cr_pr_product_top
It also seems to support resolutions up to 1920x1200
Molex to SATA, lose all your data
https://linustechtips.com/topic/212143-kvm-switches/#findComment-2880052
Thats what i would want, didnt think prices would be that high, i could really use one :(
https://linustechtips.com/topic/212143-kvm-switches/#findComment-2880065
I have got a Belkin Soho and the thing has some latency issues. If I use my mouse at higher DPI settings then it freaks out.
I bought mine off of ebay for very cheap. Keep an eye out on there as there is some bargins to be had!
https://linustechtips.com/topic/212143-kvm-switches/#findComment-2886192
