It's easy to regurgitate information because someone else told you to get it or that it was awesome.  My question is what makes a mobo good or even great.
That is to say leaving the brand out, and focusing solely on what features, options, and extras should one look for in a mobo.
This is in terms of a budget gaming mobo and a high end mobo.
https://linustechtips.com/topic/211376-mobo-features/
So in other words buy based off of aesthetics (if I'm into that), OC Software, and expansion (PCI and RAM) is what I'm getting from the video?
That's a bit disheartening.  I was expecting and hoping for some scientific answer similar to that of a CPU.
https://linustechtips.com/topic/211376-mobo-features/#findComment-2868987
Well there's chipset at the core, Z97 being the best with the most features. Then cheaper boards have wrose audio and maybe not intel lan chips etc.
https://linustechtips.com/topic/211376-mobo-features/#findComment-2869030
