I need help choosing a gpu
Go to solution Solved by Lazmarr,
Get the 280 and overclock it, if you can't get the 280x  :)
Hello guys, my hd 6850 died after 3+ years of heavy use and im looking for something good and reliable.
I cant choose between these cards because i read a lot of good things and a lot of bad things and im not very experienced so here are the cards:
R9 270X ===> http://www.newegg.com/Product/Product.aspx?Item=N82E16814121802
R9 280 ===> http://www.newegg.com/Product/Product.aspx?Item=N82E16814121867&cm_re=ASUS_R9280-_-14-121-867-_-Product
R9 270X XFX ===> http://www.newegg.com/Product/Product.aspx?Item=N82E16814150686R&cm_re=XFX_Double_D_R9-270X-_-14-150-686R-_-Product
GTX 760 ===> http://www.newegg.com/Product/Product.aspx?Item=N82E16814125466
GTX 660 ===> http://www.newegg.com/Product/Product.aspx?Item=N82E16814121664
Ill be playing games like battlefield 4, wolfenstein, arma 3 etc....
My pc specs are:
Intel Core i7 2600
GIGABYTE GA-Z68MA-D2H-B3
6 gb of ram
600 watt psu
This is the second post because on the other one the guys didnt answer my question and started arguing about hd 6850 and hd 6870...
Thank you.
https://linustechtips.com/topic/211360-i-need-help-choosing-a-gpu/
I would get the 280X.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
280x should max you I think
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
Definitely 280x. Also, get 2 more gb of ram, they're worth it :)
By the way, please remember to follow your posts so you're notified when someone answers!
I plan to but it doesnt bother me at the moment and thanks for the following tip im kinda new here...
Where are you located, are those your only options?
The 280x would be my vote, i love mine. But i would suggest you get some extra ram if you can
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
Im Greek and the prices are HIGH as ****
I made a mistake its not 280X its 280 and here is the site i found them http://www.e-shop.gr/vga-kartes-grafikon-l?table=PER&category=%CA%C1%D1%D4%C1+%C3%D1%C1%D6%C9%CA%D9%CD
you dont need to know Greek to understand the basics
still the 280 then
Ps you can edit the original post
My Rig
Total: $2074.22
Gaming PC: Case: NZXT Phantom 820 Black | PSU: XFX 750w PRO Black Edition 80Plus Gold (Platinum) | CPU: Intel Core i5 4690K | CPU Cooler: BE QUIET! Dark Rock Pro 2 | MB: ASUS Sabertooth Z97 Mark S | RAM: 24GB Kingston HyperX and Corsair Vengeance 1866MHz | GPU: MSI R9 280X 3G | SSD: Samsung 840 Evo 250GB | HDD: 9TB Total | Keyboard: K70 RGB Brown | Mouse: R.A.T MMO7
Laptop: HP Envy 15-j151sa | 1920x1080 60HZ LED | APU: AMD A10-5750M 2.5GHZ - 3.5GHZ | 8GB DDR3 1600mhz | GPU: AMD  HD 8650G + 8750M Dual Graphics | 1TB SSHD
