Old AMD CPU overclocking problem
Solved by msvelev,
I cleaned the stick with a rubber eraser, then blowed with some canned air on it, put it back in and now everything works just fine ![]()
Thank you two for the help!
Hope I'll be able to return the favor
P.S. not sure if it's polite to pick my answer as best but it describes what solved the problem
kasdashd ·
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4
play_circle_filled
Latest From ShortCircuit:
