I build my computer few days ago and everything is running great, but whenever i press the restart button on the case or on the windows my screen goes black and starts saying no signal and my mouse and keyboard get disconnected too until i turn off and on my computer at the back of the case.
My build is:
i5 4690k
MSI GTX 770 4gb
MSI g45 Gaming motherboard
adata 256gb SSD
corsair 650w power suply
corsair vengeance 8gb ram 1866mhz
https://linustechtips.com/topic/211060-problems-when-i-restart-my-computer/
Why does a restart button matter? I can't even recall the last time I used mine.
Main: i7 2600 | ASUS P8Z68-V | 2x4GB Vengeance 1600 | GTX 580 | WD Blue 1TB | Antec TP-650C | NH U12S | W7 x64
Backup: X6 1090T | MSI K9A2 Platinum | 4x2GB XMS2 800 | GTX 550Ti | WD Blue 1TB |  Antec VP-450 | CM TX3 | W7 x64
when resetting your computer there will be a point when everything gets turned off. the entire computer gets turned off exept for your bios which turns it back on. at that point your screens will turn off/go into power save mode. its perfectly normal. now if the pc doesnt restart then you have issues. from what i read in your explanation the keyboard/mouse/monitors turning off is perfectly normal. they should resume functionality after a few seconds when the pc starts booting up again.
I checked the connectors and they were fine. It does not really bother me, I mean i can do everything without the restart by just shuting down my pc and turning it on again. But it made me feel bad that meybe i did something wrong that all. Thank you everyone for the help!
