Hello, I see you are having issues with connecting the MisFit Shine. Could you please go more into detail on what you mean? What exactly is it asking for? I see it is asking you to go to the Network Settings, but what does it want you to turn on? Bluetooth? WiFi?
  •     | CPU- AMD FX-8350 @ 4.0 Ghz | Motherboard - Asus M5A99FX PRO R2.0 | RAM - G.Skill Ripjaws X 16GB 1333mhx (2X8GB) | GPU - Asus Radeon R9 280 @ 980mhz | Case - Antec GX500 | Storage - Western Digital Purple 3TB 5400RPM | PSU - Corsair CX750M |
   | Display - Asus VW246H 1080p @60Hz 2ms GTG | Keyboard+Mouse - Logitech S510 | Sound - Realtek Intergrated Audio :( | Case Cooling - 3x Antec Stock 120mm fans (Planning to add more) | Headset - Turtle Beach X12 with virtual surround | OS - Windows 7 64 Bit Pro |
https://linustechtips.com/topic/210854-help-with-misfit-shine/#findComment-2862110
It doesnt say it just says to check network settings.
https://linustechtips.com/topic/210854-help-with-misfit-shine/#findComment-2862117
Is Bluetooth on?
https://linustechtips.com/topic/210854-help-with-misfit-shine/#findComment-2862120
Can you type EVERYTHING on the screen?
https://linustechtips.com/topic/210854-help-with-misfit-shine/#findComment-2862123
If you know how, post a screenshot so I can try to figure out what is wrong.
https://linustechtips.com/topic/210854-help-with-misfit-shine/#findComment-2874256
