hey this is my first build, and i want to get all of your opinions and help on it here it is: http://pcpartpicker.com/user/TotalSandwich/saved/DTRYcf
NOTE: i already own a gtx 770 2gb, so that is the GPU i will be using
Looks fine.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/210739-good-first-build/#findComment-2860118
https://linustechtips.com/topic/210739-good-first-build/#findComment-2860120
Looks good!
https://linustechtips.com/topic/210739-good-first-build/#findComment-2860130
Get a 550w PSU, I don't think you need that amount of wattage, but don't quote me on that
Specs: CPU: AMD FX 6300 Motherboard: Gigabyte 970A DS3P RAM: HyperX Fury 16GB 1866MHz GPU: MSI R9 270 OC edition Case: Sharkoon VS3-S SSD: Samsung 840 EVO 120GB HDD: 1TB Caviar Blue PSU: Corsair CX500W
*If I say something that seems offensive, please don't take it seriously, it was most likely meant as a joke/sarcastically*
https://linustechtips.com/topic/210739-good-first-build/#findComment-2860150
550w is enough for a single gpu, but I just assumed he intends to SLI down the road.
PSU Tier List | CoC
https://linustechtips.com/topic/210739-good-first-build/#findComment-2860160
