I have been having random BSODs and also game/program crashes. I have been having these sense I built my rig. I have tried everything i know to find the problem but to no avail. Please help me. I will provide more crash reports if you guys tell me what to post.
[EDIT]
(wrong specs on first link)
Problem signature:
  Problem Event Name: BlueScreen
  OS Version: 6.1.7601.2.1.0.768.3
  Locale ID: 1033
Additional information about the problem:
  BCCode: 5
  BCP1: FFFFFA80092E74C0
  BCP2: FFFFFA80096E74C0
  BCP3: 0000000000000000
  BCP4: FFFFFA804F06FB50
  OS Version: 6_1_7601
  Service Pack: 1_0
  Product: 768_1
Files that help describe the problem:
  C:\Windows\Minidump\090514-8361-01.dmp
  C:\Users\Joel\AppData\Local\Temp\WER-12433-0.sysdata.xml
https://linustechtips.com/topic/210054-bsod-and-program-crashes-please-help-me/
Well it sounds like you don't have than many important files on your PC if you just built it. In this case, you might be best off just reinstalling your OS and taking another go at things.
If you don't want to do this, then you'll need the error message on the Blue Screen itself. It should be in one of the corners if I remember correctly, although I don't remember which one. (bottom right maybe?)
//ccap
I have tried re-installing windows once already. Here is a picture of one of the BSODs, but it is not the exact some one that the error report in my first post is from.5ptG7TK.jpg
Does this keep popping up? If not, something might be faulty.
What do you mean?
Is this the first time you see this BSOD error?
