PSU cable sleeves
Go to solution Solved by daemonowner,
Could you elaborate what extensions are(sorry I'm new to dealing with modular power supply cables and such).
These are extensions. You don't connect them directly into your power supply. They're extensions for the power supply cables.
http://www.silverstonetek.com/product.php?pid=371&area=en
On the other hand, there are cable kits like these from Corsair and EVGA. You do directly connect these to your power supply. They usually only work with certain power supplies due to the pin layout (Corsair sets only work with certain Corsair power supplies, EVGA sets only work with certain EVGA power supplies, etc), and they're often expensive.
http://www.corsair.com/en-au/professional-individually-sleeved-dc-cable-kit-type-3-generation-2-black
Do you want extension cables or...?
Extensions work with any power supply, since they connect to your normal cables and you hide the normal cables behind the motherboard tray etc. A set of individually sleeved cables like those you can buy from Corsair or EVGA only work with certain power supplies, depending on the pinouts for the power supply.
https://linustechtips.com/topic/208903-psu-cable-sleeves/#findComment-2835011
https://linustechtips.com/topic/208903-psu-cable-sleeves/#findComment-2835022
https://linustechtips.com/topic/208903-psu-cable-sleeves/#findComment-2835094
I originally wanted to try putting sleeves on myself to say I did it but I guess I could go this route, thank you.
https://linustechtips.com/topic/208903-psu-cable-sleeves/#findComment-2835142
To sleeve yourself, check out frozencpu.com
https://linustechtips.com/topic/208903-psu-cable-sleeves/#findComment-2835822
I have little to none manual skills... I would love to sleeve my cables but I also feel like I would f*ck everything up... :(
CPU: Intel Core i7-4790k | CPU Cooler: Noctua NH-D15 | Motherboard: ASUS Sabertooth Z97 MARK 1 | Memory: Kingston HyperX FURY 16GB 1866MHz | GPU: Gigabyte GeForce GTX 770 4GB Windforce
Storage: Samsung 840 EVO | PSU: CM Silent Pro 720W | Case: Phanteks Enthoo Luxe | Headset: Corsair Vengeance 2100 | Keyboard: Logitech G710+ | Mouse: Razer DeathAdder Chroma
"You see, one can only be angry with those he respects." - R. Nixon
https://linustechtips.com/topic/208903-psu-cable-sleeves/#findComment-2852761
