I am about to order the parts for my new PC and I want to know if anyone sees any problems. here are the parts.
Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case ASUS GTX760
ASUS Black 18X DVD-ROM 48X CD-ROM SATA DVD-ROM Drive ASUS GRYPHON Z97 LGA 1150 Intel Z97 Intel Core i5-4670K Haswell Quad-Core 3.4GHz LGA 1150 84W
Crucial MX100 CT256MX100SSD1 2.5" 256GB SATA III MLC Internal Solid State Drive (SSD)
Fractal Design Integra R2 750W ATX12V SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Power Supply
(x2) CORSAIR Vengeance 4GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ4GX3M1A1600C9B
AM I MISSING ANYTHING?!?!?!
Please let me know if you see any problems, also how do I know if the case is big enough?!?!?
Thanks for your help.
https://linustechtips.com/topic/207805-help-me-build-my-pc/
-PSU is overkill unless you plan on SLI in the future
-If you plan on overclocking you will need an aftermarket CPU cooler.
-You also didn't say that you had an HDD, a 256GB SSD will fill fast with games.
-You should also get a single 2x4GB kit of RAM instead of two 4GB kits, it will be cheaper.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/207805-help-me-build-my-pc/#findComment-2819061
maybe get a 212 evo cpu cooler from coolermaster if you don't want to go with the stock fan. also get the 4690k instead of the 4670k as it has much better performance and cooling :D
https://linustechtips.com/topic/207805-help-me-build-my-pc/#findComment-2819071
The performance is exactly the same, the only things that changed are some of the power delivery and the IHS refinements which only affect overclocking.
https://linustechtips.com/topic/207805-help-me-build-my-pc/#findComment-2819088
I think you are forgetting to turn off caps lock.
https://linustechtips.com/topic/207805-help-me-build-my-pc/#findComment-2819090
the 4690K has exactly the same performance only better temps.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/207805-help-me-build-my-pc/#findComment-2819092
 What CPU fan would you recommend
Hyper 212 if you are on a strict budget, Be quiet! Dark rock 3 if you have some more and noctua NH-D15 if money is not a concern.
https://linustechtips.com/topic/207805-help-me-build-my-pc/#findComment-2823397
